Old 02-14-2014, 06:47 AM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Default Re: 1/10 Liebherr Excavator R 984 Litronic
Originally Posted by thuangs View Post
Thanks for sharing Markus! These parts look extremely beautiful! I also found it difficult to do cooper blazing with different material, i.e. my cylenders are made with SS304 but tube was cooper. Even I heat it to extreme high temperature, join won't hold very well. But yours are all the same...blazing result shoudl be good.
I am a big fan of your R984C!
Best regards,
Kevin
@Kevin
Hi, what kind of soldering/ brazing? Silver or soft? Did you use any flux?
@Joe
well, yes... the bucket... don't forget the chains
let me just throw in the counter weight. It was milled from a solid Aluminum block 410x180x80mm with a weight of 16Kg. The finished Block is round about 5Kg and way too light. It will receive some inlays from lead to bring it to the necessary weight again. I try to bring it up to 17Kg. First some drawings, you can see the lead blocks inside the weight, how it should be finished and right from the mill.
Old 02-14-2014, 08:22 AM
JAMMER JAMMER is offline
Thumbs up Re: 1/10 Liebherr Excavator R 984 Litronic
Hi Markus that Permatex sealant is Permatex Viscosity Hydraulic Pipe Sealant # 54550 I get it in 50 Ml bottle on line for $24 and change from ALL-Spec Ind . Ed
Old 03-21-2015, 03:31 PM
JoelSund JoelSund is offline
JoelSund is on a distinguished road
Hi
I must say that it was a very good looking 984.
I can not believe how you make all the parts. Do you have the original drawings or do you have an excavator disassembled that you copy?
To my next question. I have repaired a 984 many times and my brother drives one at the job. He is totally in love with it.
So I have planned to do a small copy of the counterweight to his birthday, but I have problems with the drawings. then I saw that you've just made one of those, and one that looked very much like the original.
So I was thinking of doing a little long shot and hear if you stil have the cad drawings and if you want to sell a copy to me.
I would be very grateful if you could. I'm a little tired of climbing on the machine with my measuring tape
Best regards, Joel Sundstrom
