Old 02-16-2014, 07:11 PM
Bg416 Bg416 is offline
Bg416 is on a distinguished road
Default Re: Sluggish hydraulics
I was told to use any antifreeze and the motor sounds like its running at full power
Old 02-17-2014, 09:58 AM
cosworth34677's Avatar
hi i have found with the hrc stuff they are really big on the servo's being set upt just right. i had sluggish running gear for a while. and found that this was the problem, also little giant is right it dose any but, the kit i got seems to work better with a 70% -20% water mix. it seem to bee just thin enought let the hydraulics move free, but slick enough to lub up everything. staight antifreeze beside being nasty to clean up seem to run the pump really hot(it dose anyway)and get sluggish after while.
Old 02-17-2014, 11:30 AM
daddycool75 daddycool75 is offline
daddycool75 is on a distinguished road
Hi just as cosworth said make sure your servos are set at the right point and the valve block as well, the screws on the block should be at the top looking down on the block.
Set the servo arms to suite.
