Old 02-20-2014, 07:06 PM
Lmackattack's Avatar
Default Re: Limit switch wiring help
Great info guys....!! . I too was wondering how to do this also...So basicly we need
2 normally closed limit switch
2 diodes
Motor
Esc
That's very simple to wire up...
Wires to connect everything...
Old 02-20-2014, 07:25 PM
Supermario's Avatar
Just one other thing to consider is,
You need to use switches and diodes that can handle the amperage required to run the circuit. I'm not sure what size motor and drive you are using.
My dump truck switches and diodes are rated for 1 amp. I have yet to test the box with a full heavy load and see if it blows a diode or switch. If it does, I'll try a 2 amp version.
