Old 02-20-2014, 07:25 PM
Supermario's Avatar
Default Re: Limit switch wiring help
Just one other thing to consider is,
You need to use switches and diodes that can handle the amperage required to run the circuit. I'm not sure what size motor and drive you are using.
My dump truck switches and diodes are rated for 1 amp. I have yet to test the box with a full heavy load and see if it blows a diode or switch. If it does, I'll try a 2 amp version.
