Old 02-21-2014, 06:44 PM
Supermario's Avatar
Default Re: Reduction question(again)
Originally Posted by Lmackattack View Post
Regarding the motor turn question that is often brought up...I have 55,65, and 80 turn motors from rc4wd.they are the cheep $10 motors they sell.
the 55 is the fastest and seams more powerfull than the 80 turn
For example the truck with a 55 turn will run up a steep hill, loaded, at little loss of speed with no struggle to it. The 80 turn on the other hand struggles and slows to a crawl. I would expect the 80 turn to pull the hill with ease if it truly has more torque...
Can someone explain if I missed something....
Don't feel bad bud. Every time I read about motors I get a different explanation about turns and torque. If one thing is constant , you get what you pay for.
It is very possible for a 55 hand wound motor to be stronger than a 10 dollar 80 turn machine wound? More turns ain't better than less if not done properly
Mario
