Old 03-01-2014, 08:22 PM
Default Re: Reduction question(again)
Originally Posted by Lmackattack View Post
Regarding the motor turn question that is often brought up...I have 55,65, and 80 turn motors from rc4wd.they are the cheep $10 motors they sell.
the 55 is the fastest and seams more powerfull than the 80 turn
For example the truck with a 55 turn will run up a steep hill, loaded, at little loss of speed with no struggle to it. The 80 turn on the other hand struggles and slows to a crawl. I would expect the 80 turn to pull the hill with ease if it truly has more torque...
Can someone explain if I missed something....
Out of all those motors, the 55 turn should be the fastest, but the 80 turn should have the most torque. Why doesn't it? There could be lots of reasons, but motors are not all created equal. Especially not when you are only spending $10.
