Old 03-02-2014, 03:44 PM
Lmackattack's Avatar
Default Re: Motor uestion about turns,vs speed,vs torque
I used an rc4wd 6 tooth pinion with the rest of the drive train stock.
The 85 turn with a 6 tooth pinion is in my opinion way slow for a truck. Top gear with the 85 turn was about the same speed at firts gear with a 65 turn. I like to have a little of both for gears, slow for the off road and one that will keep up with me walking yet wont flip the truck over if i mistakenly turn to quickly.
surprisingly the 85 turn is to fast for my screw drive end dump. It has power to lift the empty box but I need much more reduction to lift a heavy bed of dirt.. I tried using the cheap rc4wd 4:1 reduction but it still moves the screw to quickly.
I'm trying to source a 16:1 in hopes that will lift the box when loaded.
Old 03-02-2014, 04:24 PM
Bo Wallen's Avatar
Hey
The 6 toot pinion is way small it will destroy the gear fast.......I tried that and it lasted less than 20 hours. I changed to a 9 toot pinion and there is no destruction at all. The speed is not to slow, I can do slow tricky backing.
Old 03-03-2014, 12:51 PM
weemanch weemanch is offline
weemanch is on a distinguished road
Lmack what about sonething like this on top of your 4:1 so can make it 8_1?
https://store.rc4wd.com/mobile/Gear-...Unit_c_28.html
