Old 03-11-2014, 04:48 PM
Lmackattack's Avatar
Default Re: Full frame Dump trailer build ?
Havent found a solid solution. My box sounds about the same size as yours and will also hold 3/4 of a 5 gallon bucket. I am Also trying a small screwdriver motor right now. It has 2 planetary gear reductions limiting the revs to a max of 350rpm and puts put 110 lbs of force. Problem is the out put shaft is not set up for adding a gear. I will need to have something machined. I'm also clueless how to figure out the needed power to lift a fully box of sand or dirt.
What size screw driver motor are you using? Does it have reduction?
Old 03-11-2014, 05:02 PM
Bo Wallen's Avatar
Just thinking : Is there any trust bearing installed on the screw ends ?
Old 03-11-2014, 06:11 PM
Yes I used a 1/4 -20 threaded rod with brass bushings and thrust bearings to carry both top and side load of the rod when moving...
Old 03-11-2014, 06:26 PM
Bo Wallen's Avatar
I am confused :0/ How much angle do the screw/or arms got when it start lifting the box ? the greater the stronger it will get. Any close up photo to look at ?
