Old 03-15-2014, 04:23 PM
Supermario's Avatar
Default Re: combo units
I'm very new to the metal work type tooling but on a budget. I've had my eye on this for awhile and like the fact it can cut and bend. Small yes, but so are the pieces I want to make.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=281285623236
Mario
Old 03-18-2014, 08:38 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
I would stay away from the combo units unless you are very limited on space. Much better to have separate machines. It allows you to work on 2 different things at the same time without breaking the machine set up down to do something else.
I have a similar bender/shear from Micromark. It should handle most of your smaller projects.
LYNN
Old 05-09-2014, 01:22 AM
THX_138 THX_138 is offline
THX_138 is on a distinguished road
I can't vouch for them all, but I will speak from experience.
Stay away from the cheaper lathe/milling machine combos in the $1,200-$1,500 range.
The ONLY thing I received from purchasing one was a $1,350 lesson to buy the right tool the first time and to stay away from discount JUNK!
Old 05-09-2014, 08:58 AM
Dieselchopper's Avatar
Mario
I have a maching just like this one. Works good if you don't exceed the max thickness. I pushed it cutting and bending some 0.032" thick aluminum. I broke first a pin and then later stripped a gear. It is solid but has definite limits.
