Old 03-27-2014, 09:32 AM
Acadieman Acadieman is offline
Acadieman is on a distinguished road
Default Re: Hayes HD dump truck...RCP's style
Awesome work and details!
Basic question, how do you tap for the 2-56 screws? I tried to tap threads in aluminum but broke the tap. I was going by hand, and almost wonder if using the lathe would be better.
Old 03-27-2014, 09:57 AM
For the small stuff I always drill the holes a little larger than the recommended size and tap by hand...carefully. For tapping 3mm holes, I use my cordless drill but don't tighten the chuck up super tight. Again using caution! I also use silicone spay or alcohol for lubricant.
I broke off my favorite 3mm tap recently in a customers box. The tap was getting dull and I was trying to thread a hole near a weld. The alum gets soft and galls easy where its been welded and I was trying to tap it dry(lube messes up powder coat). Anyway it broke off, I said a few bad words, calmed down and tried to grab the end that was sticking out. I got it to move but it broke off flush causing me to say more bad words. I tried heating the area with the TIG torch thinking it would swell the aluminum and make the hole loose. That didn't work but I noticed that the tap was melting so it gave me an idea. I TIG welded a nail to the broken tap and wound it right out! What a relief!
Old 03-31-2014, 10:26 AM
Ken Orme Ken Orme is offline
Ken Orme is on a distinguished road
When I tap threads I use a cutting fluid called "tap magic" It is available from USC Industrial Supply Co. I comes in a 4OZ can for $4.62. Their part # is 06492920.
You could use a lathe to tap holes but [B]TURN THE CHUCK BY HAND> DO NOT TURN THE LATHE ON[B]
It has been a long time since I broke a tap using their cutting fluid.
