#441
update on the dump truck! With all fitting and electrical testing done its time for final assembly
![]() ![]() also added a new punisher driveshaft and alloy trailing arms ![]() ![]() Now the wiring begins ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() trying to keep it neat, tidy and fit. If I plan on removing cab to replace the battery on a regular basis, its gotta be user friendly ! thanks for looking. Mario |
#442
Look great I will have some pictures to go to for reference..
Wayne |
#443
#444
Mario that is thinking
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#445
Mario you do nice work!
#446
Nice work buddy!
#447
looks awesome mario keep it up.
Zach The Bat Flowe Keep On Rollin. |
#448
![]() ![]() got some progress to report on the dump truck. thanks to 1985kenworth ( Dwayne) who posted pics of some air cleaner guards, I really liked the idea and thought I would add to this build. this truck is going to follow the look or theme Susans black pete. Black and chrome but a Kenworth. I think these will add a nice touch once the body is painted. I think I have the size, lines and angle correct? please let me know what ya think ![]() ![]() ![]() ![]() ![]() ![]() and the latest video showing all the goodies stuffed into a day cab and yet comes on and off easy enough! ![]() ![]() http://www.youtube.com/watch?v=7tbGH...&feature=share thanks for looking, all comments and suggestions always welcome! ![]() mario |
#449
The A/C guards looks spot on to me.
#450
thats cool mario im still working on mean green lol question where did you get those shocks and what brand are they they look nice i need something different can't stand the stock tamiya pink shocks thanks man
#451
A great way to improve stock suspension without breaking the bank and gives a infinite range of suspension strength depending on application. I admit they are not a scale looking shock but a great way to improve suspension strength! Oil filled and with adjustable spring tension works great. No modifying or extra hardware required to install. I've purchased from this guy many times and had absolutely no trouble. Arrives from Hong Kong in just over a week for me. http://www.ebay.ca/itm/ALLOY-REAR-SH...item5889ffc43b Mario |
#452
Thanks Big John. I think the guard turned out not bad and is close enough to capture the look I'm trying to capture.
![]() ![]() Mario |
#453
Truck is coming along nicely Mario!! I like your hidden switch trick, was trying to use that step for a receiver but did not work for me, so I left it alone.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... |
#454
Looking good Mario,!!
#455
Looks great Mario.. Lots of nice detail...
Wayne |
#456
Looks great Mario. What happens if the battery dies while the box is down? Is there a back up plan?
Reg |
#457
Thanks for all your kind words and encouragement guys I appreciate it.
![]() Yes Reg, I do have 2 backup plans actually. Both ESC's are cheap and don't have a lipo low voltage cutoff so to prevent doing any damage I bought a lipo low voltage audible alarm. As soon as I hear it chirp even once, I know it's time to raise the box a couple inches ( it doesn't take much to gain the room needed to clear the back cab plate) and replace the battery. The other plan is, you built this box with 4 screws to secure on the dumping mechanism. It fits so well and snug I'm only going to secure with the 2 in the bottom of the box and not reinstall the 2 on the front edge of it. So worst case scenario is I remove the box to be able to get the cab off. In hindsight, I guess I should have wired up a manual switch in the right side step and could have used a 9 volt battery in the fuel tank as a aux power source. But way too far into this build to do that now ![]() I'm sure the audible alarm will work fine. It's loud! You can't miss it when it goes off! Mario |
#458
is it that loud...wow probably cause an evacuation in the neighboring buildings.they will think its a fire alarm
owner/operator.."got to operate to own" dwayne |
#459
Instead of taking the cab off to charge , solder another plug to the battery and tuck the plug out of the way underneath the cab, that way you just pull out the plug and plug in the charger .just make sure the Esc is off .I have done this on a few of my Toys that are difficult to access the battery
#460
![]() ![]() ![]() Quote:
I blow a battery on the work bench, no problem. If I fry a battery while in the truck.... Big problem! ![]() Thanks for the input though. It all boils down to personal preference I guess. If I asked 20 guys about charging batteries in the truck, 10 would say not a problem and the other 10 would say don't do it I bet ya ![]() ![]() Mario |
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
