Well here are a few picks of mine, I still need to decide on a color. I did install the MFU and Tamiya aluminum rims.
Lights on ![]() ![]() ![]() Lights off ![]() ![]() ![]() Basicaly it is the same kit but there are some minor detail changes. Silver shock bodies like used on the trailers no more pink. No springs in the shocks, now they use an oring and use them as a friction dampener. They give you two bearings per axle to be used next to the ring gear on each shaft but the rest are all still bushings. They give you two bearings for the trans to be used on each end of the output shaft. They have changed the spring configuration on the shaft for gear shifting. They went from three to four springs with some washers and clips as well. I will say it does seem to shift smoother and faster than the other version. Overall the changes all seem to be improvements. Like the Knight Hauler this truck comes with parts to install the MFU that do not come with the MFU so save them if you do not install an MFU you may to in the future and you will then have to find them. Travis
Well Travis you got me wanting to start building mine.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
