Old 04-04-2014, 09:10 PM
avel avel is offline
Default Re: LR634 is HERE!!!!! Tracked loader
Putting the tracks together, just finished one side. Taking a break. Also covered some areas in JB Weld on the main chassis, areas where if I screw up it won't be seen, not that it can't really be fixed. Also glad I read up on how to properly use it, found out that rubbing alcohol is to be avoided for cleaning, also anything with petroleum distillates in it. Acetone, lacquer thinner and soap and water are recommended. I bought some acetone. Also last night I installed ER9X on the transmitter. Has a lot more options and capabilities.
