Old 04-05-2014, 11:32 AM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Default Re: 1/10 Liebherr Excavator R 984 Litronic
the small tubes were pressed into the side-parts, receiving the roller-tubes first. Then connected with the bolt through the small tubes, the bolts were loctited into the left side parts. The last bolt is secured with a little worm screw placed under a chain shoe (1.st picture). As a reminder for the invisible chain lock there is a small center boring in the lock bolt.
The shoes were made of steel while the side parts were made out of aircraft aluminum.
Old 04-05-2014, 01:08 PM
JAMMER JAMMER is offline
Markus the bucket weighs 33.5 Lbs you are going to need a crane to lift it and move it when it is all finished. Excellent work and a lot of detail it's coming along well. It ought to be able to move some dirt when finished. Ed
