Old 04-11-2014, 11:48 PM
ngward79's Avatar
ngward79 ngward79 is offline
ngward79 is on a distinguished road
Default Re: Vario Digger in Cat Yellow
I don't have any experience with construction models as much as i would love to but have been building my own R/C vehicles for years and do all my own electronics + did car electronics professionally for 6 years and would be willing to help out. I live in Milan Ohio, basically half way between Lorain and Sandusky.
Old 04-12-2014, 12:33 AM
avel avel is offline
BEC = Battery Eliminating Circuit
Most ESC's (Electronic Speed Controllers's) nowadays have a BEC to eliminate the need for a separate battery to power the Receiver and servo's.
The plug from the ESC will have a Ground/Negative, Positive, and Signal. Brown or Black will be Ground/Negative, the middle wire is Positive, and the last one is the Signal wire.
If I wanted to NOT use the BEC capabilities of an ESC I would remove the Positive/middle wire from the connector. That would leave the Ground/Negative on one side of the connector and the other side would be the Signal wire.
Also Dimension Engineering has all the information about the Sabertooth ESC's on their site.
I hope I explained it properly, this stuff is confusing.
