Old 04-25-2014, 05:34 PM
calum_scania's Avatar
Default Re: Liebherr 922
Judging from the pics, this looks like an old machine... early 2000's?
It probably has 1.5mm ID hose & fittings...
Just to go to 2mm ID plumbing speeds up the hydraulic flow dramatically with your current fitted Leimbach pump... similar to this one.
http://youtu.be/yNMtwIds6Vc
The age of the machine I am unsure of? As it was second hand to me..
I did think about changing the hose size too, but I was unsure if it make that much difference? It was horribly slow before, so I changed the pressure on the pump which has made it better now.
I decided to change the pump as the Leimbach would be working too hard all the time to keep everything moving. The machine works very well, the electronics will be replaced and modified as the pump runs continuously and the track control takes up a huge amount of space
Calum
