I'm glad your going with one motor and steering clutches, you can be the guinea pig to see if works.lol Any more progress on the pump?
Joe |
well I got my pump working
![]() ![]() ![]() ![]() ![]() IHSteve
Nice work on the pump - a vane pump you say. Wow, nice work. Would a press fit bronze SAE863 collar on the shaft help seal it? Are you planning to make the valves? If so, are you going to do a closed or open hydraulic system?
Nice progress Steve. Pump looks good!
Those HD brand servos I told you about on the phone don't like to sit for a long time under load, they have so much holding strength that they burn up from heat. So, they probably would be good to move/hold valves.
I'm might try something off the shelf first . not sure yet on open or closed . as for seal , I just used what I had laying around to try it out . Quote:
thanks Scott , any servo holding a load for a long period of time is not good for it , I would think . I'll cross that 1 when I can get to it .
