Old 05-03-2014, 03:40 AM
Seilbagger's Avatar
Seilbagger Seilbagger is offline
Seilbagger is on a distinguished road
Default Re: simple device to build cheap and exactly leave springs
Originally Posted by Trackerman View Post
Sailbagger,
Nice work. One question can you show how you obtain the set in the spring. Set being the curve.
Thank you
Paul
Hello Paul,
i hope to translate it correct: While cutting the bronze with scissors, it curls. I turned the strpes manual in the correct Position, only little and fast work.
Best Regards
Wolfgang
Old 05-03-2014, 06:05 AM
rsd53 rsd53 is offline
rsd53 is on a distinguished road
I really like what you have done. What thickness of bronze are you using, and what material are you using to hold the springs together?
Rob
Old 05-03-2014, 10:53 AM
Seilbagger's Avatar
Rob
Hello Rob,
the thickness is 0,5mm. The parts for hold the springs together is in every windshield wiper under the rubber. Naturally i have used an old. The parts a pressed with aid of a vise.
Best Regards
Wolfgang
