Old 05-13-2014, 04:04 PM
Erik79's Avatar
Erik79 Erik79 is offline
Erik79 is on a distinguished road
Smile Re: CAT330D-L full hydraulic
Thanks Jammer, the plumbing work is less simple than it seems, it's true.
For the more tight turns in fact i have choosen to use the copper tube than the brass one. Moreover i have used some little brass wheels built by lathe with the same radius of the bend on the external and the radius of the tube in section; this is to prevent the buckling of the tube.
The problem on this kind of model is that we have to use tubes of bigger dimensions than the real machine and is very hard to find the way they have to pass through...
Old 05-15-2014, 04:02 PM
Erik79's Avatar
Hi, i am here again with another little step...
This counterweight is only the model to cast the real piece with aluminium and first it has to be fed up, sanded, smoothed and Painted.
For now i only have started to fed it up...
Bye...
Old 05-21-2014, 05:35 PM
Erik79's Avatar
Hi everyone, on monday i finished to prepare the model of the counterweight and i painted it. I have done some modification to the shape of the hooks for casting requirement.
And today i have got the casted piece...
Goodbye everyone.
