Old 05-19-2014, 03:50 PM
mavrick0 mavrick0 is offline
mavrick0 is on a distinguished road
Default Re: My Cascadia build.
espeefan has you covered rctrucker2 and he is correct. All I do is just make a list out of the manual and I'm lucky enough I have a good supplier in my area I can just walk into and put in an order. I've spent about $300 on the last two orders I've done but that's including the truck and trailers I'm working on too. I wish I would've looked at McMaster first for the 2m screws but I'll be doing an order with them and getting the button head screws as well versus the cap screws I'm using now. But I will say if you go this route get a good set of drivers. I use a set from Dynamite RC and just had to recently change the tip after 2 years of use but a good set will make your life a lot easier and less likely to strip out the head of a screw.
