Old 05-22-2014, 06:39 PM
dmess62's Avatar
dmess62 dmess62 is offline
dmess62 is on a distinguished road
Default Re: Sabertooth 2x5 help needed
The more I'm reading and trying to research. It looks like some wire where soldered to board are shorting each other. When I look real close where they go in the wires touch each other when moving them around. Both throttle and turn. This is when it shuts off. Could I get the strands seperate s then use some kind of glue to keep them apart
Thanks for looking. All comments, suggestions, and constructive criticism are appreciated.
Dave
Old 05-22-2014, 07:50 PM
SmallHaul's Avatar
If you were sure you got the wires away from each other you can place a dab of clear silicone (like caulking silicone at lowes) on it and that will keep it from happening again.
Scott
"No load is too Small"
Old 05-24-2014, 04:12 PM
dmess62's Avatar
I plugged in the battery. And used a toothpick to get the wires set in the right location where the light was on and put some clear silicone on it. We ll see how it works
Dave
