Old 05-24-2014, 02:23 AM
avel avel is offline
Default Re: LR634 is HERE!!!!! Tracked loader
I need to put in a rubber stopper inside the spring, had the chain skip while backing up an incline with a fully loaded bucket. I ran the loader outside for about 3.5 hours. I thought I had the cooling fan running of off 6 volts, but it was 5v. This time I ran it off of 6v. I have the weight around 19-20 pounds. I need to move the weight forward, or just reduce how much is in the back. I used some magnets to attach the cab to the body.
I am going to shorten the battery leads too, they are far too long. I cut the sheet metal divider some more so that I could route the servo wires differently.
The battery was at 11.3v when I decided to come inside because of the wind.
