No juice at all? If the bad cell really does read super low, I wouldn't try to revive it. It went bad for a reason. Likely an internal short that drained it. I would be leery of trying to charge it, or run it under a load, even if it can be recovered. It's not really worth the collateral damage it could do. A bad cell that is revived is likely going to be quite unstable.
Out of curiosity, was the battery in storage for a long time? It's suggested to store LiPos at 50 or 60% capacity, or no less than 3.7 volts per cell. Best to check their voltage levels at least once a month to see how balanced they are, or even cycle them.
Nathan |
no last used at cabin fever . this 1 pack always been a lil touchy It happen before but it had at least 3.x volts in all the cells just the balance was way out . I's puffy too since that last time . These are for the loader but not to concerned as I'm gettin some bigger 1s from max amps . these where just $50 venoms I lost count of the cycles I put them through too .
