Old 11-15-2010, 07:14 AM
Trixx Trixx is offline
Trixx is on a distinguished road
Default Re: Bruder Delta tracked loader
Hi,
How do you use the channels on the radio?
Somthing like my drawing?
/Andreas
Old 11-15-2010, 11:50 PM
SmallHaul's Avatar
Originally Posted by Trixx View Post
Hi,
/Andreas
The bottom drawing is how I like to operate but, I steer with my right.
I decided I should keep the prototype Loader for myself and run the heck out of it to make sure everything holds up nice. After running it for a couple of hours moving dirt I noticed that the motors where getting really hot because of the 205:1 transmission that I was using. If you listen to motors in the video they are screaming at anything over half throttle. So, I put the heavier duty tamiya tranny in it (the gears are twice as thick) and now the drive ratio is 115:1 and now the motors never go over 130 degrees even after 1 hour of constant work. It still has power to spare and it sounds much better without the motors screaming.
I was asked to make a video with it running slower. I didn't realize that a Cat 297C has a top speed of only 8.5 mph.
http://www.youtube.com/my_videos?feature=mhum
Scott
"No load is too Small"
