Hi
![]() Just a small update. The position of the stear servo wasn't as expected. In the past I only created a temporary solution with an ugly PS plate. Now I wanted a solution that hides the servo between the frames. So I two holders of brass with a threaded pin soldered in to fasten the servo. The frame got 4 holes and the holders fitting screw threads. Done... ![]() ![]() ![]() ![]() In the meantime I started to paint the cabine. It's nearly finished, only the clear coat layeers must be sprayed.
Greetinx Peter To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
