Old 06-09-2014, 11:09 AM
gismow's Avatar
gismow gismow is offline
Default Re: Custom build of aMercedes Benz New Actros
Next step: The Backlights
The rear mud wings are bought (MAN), but the rear lights are custom build again.
After finalizing the rear lights, the module between the lights was the next part. It holds the distribution board for the rear lights.
After that, I had an absurd idea. I wanted to have a feature that no one other has. So I started to work on a curve light. If the stear is turned, the day lights beneeth the fog light turns into the same direction.
This was the first version
In the middle a bowding cable was fixed and a servo placed in the cabine was mixed into the stear servo.
A few month ago I implemented Version 2 made of brass. It's placed inside the front grill and does not need any servo in the cabine anymore.
Will be continued....
Greetinx
Peter
Old 06-09-2014, 04:12 PM
gismow's Avatar
Here's a short video shown the curve light.
And another one...
Greetinx
Peter
Old 06-09-2014, 04:22 PM
gismow's Avatar
Some pictures about the making of the rear light
Greetinx
Peter
Old 06-09-2014, 04:50 PM
gismow's Avatar
Next item was the air intake andthe roof.
After the paint job for the roof was done, I decided to repaint the front.
Greetinx
Peter
Old 06-09-2014, 05:20 PM
gismow's Avatar
Next item were the side trim panels. They were made of 2mm and 0.5mm styrene plates.
and the fuel tanks and the holders for the side trim panels
And after another paint party...
Here you can see below the connector for the sound module and above the jumper to configure if the sound module should work with the connector or with the IR Diode.
Greetinx
Peter
Old 06-09-2014, 05:40 PM
gismow's Avatar
The last greater sub project were wind deflectors and a roof spoiler with backfire lights.
After some tests I started the construction
First test...
After the second was done, the spoiler followed...
The holders for the side bars
Greetinx
Peter
Old 06-09-2014, 05:44 PM
gismow's Avatar
Final result before the paint job started
and after the paint job
And a final video of it...
Greetinx
Peter
