Old 06-09-2014, 04:50 PM
gismow's Avatar
gismow gismow is offline
gismow is on a distinguished road
Default Re: Custom build of aMercedes Benz New Actros
Next item was the air intake andthe roof.
After the paint job for the roof was done, I decided to repaint the front.
Greetinx
Peter
Old 06-09-2014, 05:20 PM
gismow's Avatar
Next item were the side trim panels. They were made of 2mm and 0.5mm styrene plates.
and the fuel tanks and the holders for the side trim panels
And after another paint party...
Here you can see below the connector for the sound module and above the jumper to configure if the sound module should work with the connector or with the IR Diode.
Greetinx
Peter
Old 06-09-2014, 05:40 PM
gismow's Avatar
The last greater sub project were wind deflectors and a roof spoiler with backfire lights.
After some tests I started the construction
First test...
After the second was done, the spoiler followed...
The holders for the side bars
Greetinx
Peter
Old 06-09-2014, 05:44 PM
gismow's Avatar
Final result before the paint job started
and after the paint job
And a final video of it...
Greetinx
Peter
Old 06-09-2014, 06:05 PM
gismow's Avatar
Finally I'd like to give you an overview about the technical facts.
The truck is controlled via a spektrum DX8i and an AR8000 (8ch) receiver.
The speed controller is a Servonaut E20 with cruise control.
The motor is a Servonaut GM32U370.
The sound module is a USM-RC-2 from Beier Electronic
The cruise control is a very cool feature, but the change between forward and backwards is a bit complicated. The lever must be pulled down, after that it must be moved right (forward) or left (backward), back to center and upwards again to the middle. This is an annoying procedure, so I designed a small module based on an ATMEL ATMega328 to do this work for me.
The features:
A seperate channel is used changing the gears. It's a 3-Position switch representing forward, idle speed and backward.
If the gear channel is switched to idle speed, the speed is automatically reduced until the truck is standing still. This is measured by the sound signal the E20 is delivering. If the gear is switched to for- resp. backward, the module simulates the gear process defined by servonaut and after that the standard signal is send to the E20.
If the truck is in idle speed, you an play with the throttle, the sound module will receive the values to play the sounds, but the speed controller will recieve a "newtal" signal, it will not move.
Here's a video showing the procedure.
Greetinx
Peter
Old 06-09-2014, 06:09 PM
gismow's Avatar
That's it at the moment.
There are two steps left to finalize the truck.
1. Windows
2. Driving mirrors
Mostly I just added pictures to the postings, because my english regarding RC is not very good. If there are any questions about pictures, details or anything else, please let me know and I will try to answer your questions as good and detailed as possible.
Good night
Greetinx
Peter
