Old 11-16-2010, 09:58 AM
Default Re: 1/16 Bucyrus-Monighan Walking Dragline
Thanks you guys, Right now I've been designing the diagonal bracing at the splice through the cross section.Tiny work here and I may have to use some of the .040'' rivets instead of bolts,there's just no room in the 5/32 angles to clear both bolt heads. Once that's figured out I can solder the braces on the top and bottom of this section.
