Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
In Contrast to the original Truck get the Model a Watercanon. But i cant´t find a working Canon to buy. So i make a own One. Its a 7mm Pipe, a 3mm Pipe with 1mm diameter and a hosepipe from a Infusion.
![]() ![]() ![]() I move the Cacon with a regular Servo. klick ![]() Here can you see the Pump, too. She carries 1,8 Litres in a Minute. klick Importend for a Firetruck... The blue Lights ![]() ![]() I use three rotating Lights from Pistenking. here is a small Video from the Lights: klick
greetz Robert |
It goes on..
![]() The Interior. I make two Pics outside the Cab an then i forget to make more Pics.. ![]() ![]() ![]() I have only these.. But not in a good Quality ![]() ![]() In the rear Door i can change between a Tank an an extern Hydrant or something else. I realised it with accessories from Infusions. ![]() ![]() The Tank is for 250ml Water. It is sufficient for 20 seconds. ![]() Video
greetz Robert |
Now cames the Technolegy.
A CTI Thor 15hc fr driving, A CTI Thor 14 for the Pump CTI ps4b8 and ps4a for the Lights An external BEC A Soundmoul from LE Elektroniks for the Siren an Enginesounds A Flashlightmodul for the two Strobes and a lot of cables... ![]() ![]() ![]()
greetz Robert |
Next Step..
![]() The Backlights. They´re from Veroma and Lego. ![]() The Roof: Its a 0,5mm Polystyrolplate... It was a bad Idea, because it was to thin... ![]() It looks good for the first time... Then breakes.. I changed it meanwhile to a Aluminiumroof. ![]() ![]() ![]()
greetz Robert |
Next Step.
The Hose Reel (Is it the right Name?) Its a wooden Reel with Polystyrolsticks. ![]() ![]() ![]() ![]()
greetz Robert |
Another Step
![]() ![]() ![]() ![]() The Sirens an a Fender for the Lights. ![]()
greetz Robert |
You have put a lot of thought into this, and it is turning out nice.
![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
