When i first put it in the truck about 7 months ago it worked fine.. i repainted the truck, and put everything back together, and now everthing works but the two servos..
Hi...
Please plug the servos directly into the receiver and test them here. Another test. If you plugged in the complete setup, please move the servo arms a bit manually before you switch on the truck. If you switch on the truck, they should be initialized and must move back to their initial position. If the don't do that, check the cables from the receiver to the MFC. Is there any damage on the cables ? Please recheck if the cables are plugged in the correct direction. Maybe you can post a photo of the MFC and the receiver for further analysis ?
Greetinx Peter To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thanks guys i got it working, i moved the servos back and forth and then turned everything back on and it worked fine.. don't know if they might have been locked up or something, never had that to happen on any of my other rc's again thanks for all the help..G
