Old 06-26-2014, 09:33 AM
Straywolf's Avatar
Straywolf Straywolf is offline
Straywolf is on a distinguished road
Thumbs up Re: Tilt nose Pete 379
Beautiful Rig, excellent work. Do you have any how to's or picture's of how you did the hood hinge? Again excellent work!!!!
Mike
Old 06-28-2014, 09:23 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Kaf343 is an unknown quantity at this point
Default Re: Tilt nose Pete 379
Mike
Thanks Mike,
I'll post some pics of the hood hinge, I use brass flat plate 1/2" x 2" bent to 90degrees, solder a piece of 1/8" ID tube to it, drill and tap the bottom of the grille and mount the plate to the grille. Then I use two pieces of brass 1/4" x 1" with three holes drilled in them, mount the two pieces to the front spring hanger and then use a 2-1/2" piece of brass rod to slide thru all three pieces. The bottom of the grille needs to be notched a bit as well.
Old 08-08-2014, 09:56 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
PaulNZ is on a distinguished road
Originally Posted by Kaf343 View Post
Thanks Mike,
Great work with the tilting Hood, how close are the guards to the air cleaners when you tilt it? have you lengthened the bonnet?
cheers
Paul
Old 08-09-2014, 02:32 PM
Kaf343's Avatar
cheers
Paul
Paul, the hood and breathers clear each other when tilting. The hood was not lengthened.
Old 08-09-2014, 06:49 PM
PaulNZ's Avatar
I think the difference must be the guards as I can not tilt the hood with the air cleaners on as the guards catch the bottom of them. My solution is to lengthen the Hood 20mm, this will make it more scale to the truck I am building anyway.
Cheers for the reply........ps: great trucks!
Old 08-19-2014, 04:25 PM
Kaf343's Avatar
Thanks Paul
Originally Posted by BRICKNICK View Post
Gorgeous Pete Keith, great job.
Thanks Nick
Originally Posted by #Hauler View Post
WOW!!! She sure is pretty! great craftmanship your and artist.
Thanks for the complement.
