Old 07-03-2014, 12:00 PM
1985 kenworth's Avatar
Default Re: airtronics rd8000 problems
Will any bind plug work or does it have to be the original
dwayne
Old 07-03-2014, 04:50 PM
Supermario's Avatar
You have a MFU so I assume the reciever is powered by that. Maybe it's not?
Is there power at the RX ? Any lights on it?
Oh, and never put external power to the reciever when connected to a MFU !
Old 07-04-2014, 12:25 AM
yes it has the mfu unit in it .the receiver does not appear to have any lights on it anywhere .i just turned on the radio and using another battery i plugged into the mfu unit and when i turned on the mfu the front wheels flickered for a split second like the servo was having a spas attack,that was it nothing else .the mfu light is on the radio says 10.4 volts but nothing,will any bind plug work ..i have a gut feeling it has to do with this receiver .i had a problem with the radio and receiver in my Blue Mule tractor ..it worked fine for about a year then one day it went screwey..the front wheels were shaking the truck would surge forward for no reason so to be safe i changed out the electronics from the futaba to the spektrum..i had no problems since .before i go buying and changing out all the electronics i really would like to have exhausted any and all probable causes first
dwayne
Old 07-04-2014, 10:13 AM
TRUCKMAKER's Avatar
If I read you right, your using an Airtronics transmitter and a different brand receiver? If that's the case I don't know how you would bind the, I don't mix those components I have always used matching brands. It does still sound like your transmitter and receiver are not communicating.
Old 07-04-2014, 12:00 PM
ihbuilder's Avatar
Dwayne , If your using an airtronics Rx , when powered up and radio on , blue light should be on (solid blue ) on the Rx . There is no bind plug on airtronics Rx . You plug A Rx batt in to the Rx with nothing else attached . I'll post a pic out of mySD-10G manual when it uploads . Don't trust after market Rx even though they say they'll werk . I never played with the MFU so I can't help there .
(edit)
Old 07-04-2014, 07:34 PM
The receiver is an airtronics Dual Conversion Narrow Band Receiver on a 72 band which is what the radio is. It looks like the original one that came with the radio.i bought the truck used from rod (stepside) and i was texting him on the weekend and even he was stumped why it is not working. I do not have the actual manual for it. I downloaded and printed a copy of it off of the internet somewhere. In the manual i printed it says how to bind but it says i need a bind plug. Since i bought it used i do not have a bind plug fir it but i have a bind plug from a spektrum radio which is why i asked can you use ant plug.
dwayne
Old 07-04-2014, 07:37 PM
When i get home i will post a picture of the setup on the truck with a picture of the receiver etc.i really appreciate everyones help here and i am taking all of it and trying everyones suggestion.
dwayne
