Thanks guys!!! It's really turning out great. Here are more pictures.
Got the nozzles mounted and added some cross beams to the deck. ![]() Now the splitter between the sprayers, had to be even to make sure it has even flow on both sides. ![]() ![]() ![]() Some hard lines to hide the motor wires ![]() This machine will have a filler access, bring another tanker or drive into a filling station ( coming soon) plug and fill. Mount made of brass as it needed to be strong cause it needs pressure to insure the filler nozzle is well seated . Let's get cracking ![]() ![]() ![]() What's a water truck without a hose reel?? Wolf got the frame built while I made the riding rollers. ![]() ![]() Simple you may think..... Took forever to get them just right and level. Everything in this build has easy removal/repair access. I hope to never need either option. Added a diamond plate to the upper deck and some serious support as this tank will be heavy and the last thing I need is for it to break on the job site ![]() Hard line mounts. Simple and easy ![]() ![]() The hose will also be functional , I just don't have it plugged yet. ![]() Let's shoot some paint on this piece shall we?? ![]() ![]() And last but not least ![]() ![]() ![]() ![]() ![]() I tested everything and all works flawlessly !!! I changed out the stupid white tanks and side skirts for plain chrome tanks. Looks much more work truck like. Now the part I hate most, making LED's and fitting all the crap inside the cab. I will post a video soon after it's all done and driving under it's own power. Thanks guys for checking out my build. I hope this gives you some ideas if you were thinking of building one for whatever reason , my reason is the weeds are taking over my construction area and now they will be history ![]() Ayoub
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... Last edited by MoRockN; 07-04-2014 at 02:06 AM. |
