Old 07-14-2014, 12:18 PM
TRUCKMAKER's Avatar
Default Re: lowering your stock tamiya suspension?
You might try adding F350 spring leaves, TamiyaUSA has them in various lengths 4 to a package for about $6 pkg. depending on length ordered.
Old 07-14-2014, 06:46 PM
TRUCKMAKER's Avatar
Sorry Nick I posted this in the wrong thread, but I was thinking about your issue. I guess I would mount the suspension higher on the frame which would actually lower the over all stance.
Old 07-14-2014, 08:44 PM
bigford's Avatar
bigford bigford is offline
you really cant with the stock set up
the center pivot plate is almost at the top of the rails.
I would try to remove a few springs or try to bend the leaf flatter
Old 07-14-2014, 09:03 PM
TRUCKMAKER's Avatar
That is true bigford but the suspension plate is very easy to modify to lower it and if you remove spring leaves you won't be able to carry much of any weight at all.
