What is it with the servonaut gear motors they are nothing special. You can get gearmotors from any where and you can make a motor mount your self with little tooling needed.
GM32U370 GM=gear motor 32=32mm motor 370=370RPM http://www.robotmarketplace.com/products/0-PL1103.html http://www.servocity.com/html/313_rp...planetary.html http://www.superdroidrobots.com/shop/
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
Hi RoadFlyer,
Just contact Servonaut directly, maybe they can ship it directly or they can name a vendor for the motor in the US. I don't know which ESC you are using, but the Servonaut motors are especially adjusted to their ESCs. Motors from different vendors often have different characteristics and so they show different behaviour if they work so they are not comparable based on technical values only. It seems that the GM32U370 is set up with the TM72. Quote from their homepage: "5-pole balanced rotor for silent running, good start-up and reduced brush sparking". The TM72 motor is absolute great. I used it in my truck with the Tamiya gearbox (now replaced by the GM32U370) and it's also in my crawler and in a CR-01. It has a very smooth start and you can move the truck millimetre accurate and it's very powerful.
Greetinx Peter To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Tags |
gearbox, knight hauler, servonaut, transmission |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
