Old 08-18-2014, 12:09 PM
cosworth34677's Avatar
Default Re: how can i get one esc two work on two receivers?
well the receivers are two different brands one spektrum and the other flysky.
the pump and the esc the is hooked two it dose two things it runs the crane and the dump bed. so what if i put a switch on the receiver that cuts off the crane receiver when not in use and vice verse when not drive the truck?
Old 08-18-2014, 07:20 PM
One esc hooked to a motor the esc controls that motor regardless of what receiver is controlling the esc. If you want one esc to control two different operations you will need some kind of a switch the to switch the outputs of the esc to the two different operations. The second receiver is not magically going to switch the esc to the other function both functions have to be wired separately.
