Reg , YOU..............ARE................KILLING MEEEEE.............WOW brother you're taking this to the next level. When do they start to ship??
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... |
Thanks a bunch guys. Over the next few months I plan to turn this into a complete "one off" truck from top to bottom. I have my fingers crossed that it turns out well and that someone will like it enough to give it a good home when it's finished.
I got back into the shop today and had my fingers on a lot of different things. I made sure that this got a little attention as well although I didn't get a lot done. Basically, I spent most of the time carefully filing the fenders and hood but I also started to make the visor. Can anyone spot the body filler? ![]() ![]() ![]() ![]() Thanks for looking! |
If I spot the body filler.......Is it mine!
![]() ![]() Wicked Reg . Simply wicked ![]() Mario |
I guess I kinda am using body filler it's just aluminum...
![]() Today was kind of a s*** show when it came to this. I started off by adding the lower muck catchers on the front of each fender. This went fine and with a little extra rod melted on I was able to clean up some body lines in the same area. I then went to my parents to use my Dads bead blaster. That went great too and I was happy to see the body all in one color. I meant to put it down and get on with some chores outside but I just couldn't stop(no lunch, no drinking, no pee breaks). I decided that the next step should be the bumper so I got busy cutting things and bending it to shape. This where the wheels started to fall off... Once the bumper was bent to shape I discovered that the right fender was almost 1/8" ahead of the left. This obviously causes major fitment issues with the bumper especially with the new fender extensions. After a few tweaks with no success I found out that the fender does come off just like on the real truck! The only problem was that I had to use a grinder to get it off and a TIG welder to put it back on! ![]() ![]() That was a lot of rambling, sorry... Here's the pictures ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for listening and looking.lol |
