Old 08-26-2014, 02:38 PM
mavrick0 mavrick0 is offline
Default Re: Wrong Radio?
I'm not 100% sure if the Tamiya radio comes with the shift gate or not. I know the Futaba version does come with one and the Tamiya is just a rebadge version.
Another thing you are going to have to watch is if you aren't using futaba (or rebadged)servo's and have to reverse a servo for it to work that will cause issues as well for having things work according to the manual.
Old 08-26-2014, 03:55 PM
Rick.K Rick.K is offline
Rick.K is on a distinguished road
The instruction manual for the Tamiya Attack states that it includes a shift gate, and the kit for the mechanical support legs for the trailer is supposed to have a gate for the right side of the controller.
The Attack radio has switches on it that permit the servos to be reversed. The radio comes with a receiver.
Tower said that it will arrive on Thursday via UPS, so I can go back to sorting out the electronics in time for the holiday weekend.
I was surprised to find that the instructions for the Knight Hauler call for using self-tapping screws when installing the cams on trhe servos. I bought the Hitec HS-645MG's for the steering and shifting. The way the cams are installed the original screw was long enough for the steering servo, but not the shift servo.
I shortened the 2.6mm self-tapping screw so that I could use it to install the cam on the shift servo.
