#961
![]() I am running 2x12's in my KH and Hayes. Like you said, they start out a bit strange on the dumps but I think the softer start is probably easier on the motors/gears. Yes I am back fishing finally! I guess we have been going fairly steady for about a month now. I made it home last night to eat a piece of my Birthday cake so that was cool.lol Hopefully the summer will be a busy and profitable one for both of us! Reg |
#962
I've been hiding out in my workshop the last month, now that the July heat is here with over 30 temps, it's a cool 18 in here to avoid the afternoon heat wave, better than ac!!!
![]() I hauled that dirt pile in front of workshop with farm fel 3wks ago. So much rain in June every week, now the mosquitos are horribly abundant, I gotta wear a mesh jacket/hood while I work outside mornings & evenings. This dirt goes to back of workshop to build up outer edges of the wall. I fill the pan with the 850, spread & pack with the pan. This moist dirt packs so well with the 4206 running over it, I walk on it myself without hardly leaving a print! https://www.youtube.com/watch?v=qmUCamQwg3Y
#963
Last night & this morning I built the framework for my workbenches for the middle room where I will sit to build/fix.
What I did last night was set the height at approx 29", and then doing the other side this morning I thought I would try a little higher @31.5"... and then I add the bridge in the middle & it's "oh $hyt ![]() ![]() 48' of workspace!!!! oh yeah!!! ![]() ![]() ![]() ![]() ![]() Here's the two stools at their various heights. ![]() ![]() ![]() ![]() ![]() I got this counter board, I can't remember what it's called, it 3/4" thick & very dense solid. And the laminate that I will put on top of that. ![]() ![]() This other end will be where the lathe & mill will sit. ![]() I got this sheet of puck board, I may use it for bench cover in the front room. That bench will be considerably higher too as I will likely be standing at that one on occasion doing whatever quick cuts/welds/bending ect. ![]() I'm headed out right now to see if I can borrow a tablesaw from my neighbor & his assistance too to cut that thick board... get the tabletops in place & the laminate glued down before harvest in a week. ![]()
#964
the Board is called MDF=Multi Density Fiber board and the shop is looking great keep up the good work
Steve |
#965
Nice workbenches Joe. They look heavy enough to build a 1:1 on! Plenty of room for lots of new project and builds. What's going into the center of the room?
#966
That's a great start Joe. I remember when our shop looked like that! Now it's full of crap and I need more space...
#967
MDF sorta rings a bell, thanx Steve.
2x6 shouldn't sag too much I hope Kent... I sat on the middle of each long span & the bubble moved a little bit. I have the outside edges tipped up to the high side of the bubble mark so the screws & tools, if they wanna roll will go towards the wall rather than off onto the floor... till I get a bunch of projects spread across the area, then maybe it will hold level. The middle of the floor will be left open for now. I have had thoughts of making a rolling bolt bin - tool carrier to drag from one project to next, regular use tools & parts at easy reach. ![]() Thanx Reg. How big is your shop & when did you build it?
#968
It's 28x40. I started planing for it in late 09 and had it finished just before summer of 2010. I did most of the work by myself and as money came in from work so it took about 6 months to complete. I wish it was a bit larger but I'm grateful for what we have!
#969
Joe,
The shop is looking great. My shop in the basement of my house is a similar size with the exact same layout. One thing I did was to put a double (5-0x6-8) set of doors from the gararge to the workshop. It makes it so much easier to move equipment and materials into the workshop. Since my basement is all conditioned I didnt need insulated doors. At Lowes a single (2-6x6-8) door was $70 and a double was $278 ![]() |
#970
My front room has a 12 foot roll-up door, so what doesn't fit thru the standard walk-in door into the middle room, I probably don't want it in there anyway. The front room is 24 x 30 and will have just one workbench on the east wall (same side as the lathe/mill in adjoining room).
#971
wow the shop is coming along well!
#972
Looks good, I have been realizing and appreciating having a lot of rolling cabinets, carts, benches ect. My work are is similar, bench on perimeter walls with open space in middle. That's where I can import, move, roll the next project into area. And I acquired a nice office chair (leather too!) that I was going to remove arms and back but have realized the back is rather useful when a eureka moment is transpiring
#973
looking good Joe hope this find's you well in to harvest hope the rains out there have not got you flooded out
#974
Speaking of roller chairs, I just broke down and purchased a drafting height roller chair, enables me to look down on lathe operations-- now I got three chairs on wheels!! But for what we are doing its nice to be mobile in the shop!!
#975
I just got one more coat of paint in the corner of the front room where building materials were moved from, then build a high workbench that I'll stand to use on occasion... then call an electrician. Once the entire shop is powered, then I'll start moving in and adding new tools...
![]() I barely started harvest Thursday on winter wht & got rained out same day... too tough to go yesterday, currently it's cloudy & 19C... gonna go out & try a different field in a few hrs that I desiccated 3wks ago, the outside round & draws that were full of weeds, if that does go (120ac worth) - that'll likely be all I'll be doing till the sun shines with 25+ temps. The 7day forecast doesn't look good with a lot of cloud & chances of rain... I hope it's wrong. Weather just not cooperating yet with a lot of rain thru later August. Everybody with different crops, whether it's yellow peas, lentils, even some early planted durum have been harvesting sprouted grain... the winter wht field I started in, the sample is 13% sprouted - automatic animal feed grade. Big yields again this yr with +15inches rainfall since planting, but quality is starting out poor. ![]()
#976
Too tough to harvest yesterday yet & today very cloudy, probably won't go tomorrow either... so to escape dismal reality I tinker in the back room today, cleaning up the last of what I hauled in a month or so ago. This dirt got too dry & too many hard lumps to spread & pack on the outer edges, so I'm just stock piling out of the way for now. Probably screen it again later & dump the lumps outside.
https://www.youtube.com/watch?v=LAgQ...BiqMGma7bs5Z3g I'll build the front room workbench tomorrow & track down an electrician Tues to get this building wired up while I'm busy with harvest. ![]()
#977
I manage to put in 2wks straight & accomplished 3/4's of my harvest, then the weather took a turn for the worst again Monday with drizzling rain most of the day. It's been brutal cold & humid all week. Thank goodness for hobbies to escape dismal realities.
![]() I made some good progress on the 490 hoe this week, I painted most of the parts during the summer, so it's assembly time. This afternoon the sun came out, the wind died down & it was relatively warm outside, so I did some hauling out with the two trk & pups when I had this eureka moment! ![]() ![]()
#978
Video looks great in the previous post! So smooth operating it.
Any progress pictures of the 490? Can't wait to see that in action. Last edited by liftmys10; 10-04-2014 at 11:02 AM. |
#979
Not much to see yet, the undercarriage is built & trying to attach upper plate. The bridge has a hollow area to fit the bl speed controls for the tracks within, but it's very narrow & not allot room with the center bearing coming down the middle. I tried to use those screw terminals to connect the speed controls to the slip ring, but they might be too big... might have to take them out & solder everything together. :/
Nobody taking a guess what the above pic might be? ![]() ![]() Well here's a few teasers... I made a vid this morning, got to edit it yet... going out right after this post to try combining, 1st I've turned a wheel since last Sunday. ![]() ![]() ![]() This is a tight hairy corner to make! ![]() ![]() ![]() ![]() ![]() ![]() Ol' whitey been down all summer, 2nd gear is clicking/skipping bad, I think the shift forks are probably wore out. The trans in this trk dates back to the 6x4 KH tractor I was running back in 02-03. ![]()
#980
Hi joe-it looks like a 5th. wheel (I think that's what it's called) but I don't know why it tilts
Currently Active Users Viewing This Thread: 30 (0 members and 30 guests) | |
