Old 09-17-2014, 05:56 PM
Cooper's Avatar
Cooper Cooper is offline
Default Re: technical question for RC gurus
I agree , when operating a 1:1 ex, usually set the idel up and start digging. Newer models have digging modes that auto throttle up and throttle down after no stick input is sensed for about 30 seconds. But in your case if you wanted you could also split the pump channel for the sound or keep how you have it and just split signal wire and install a siginal reverser before sound card. Commonly used on aircraft in landing gear.
Old 09-17-2014, 06:18 PM
apfubar apfubar is offline
On some advanced radios auto throttle and the 30sec delay after stick input can be simulated...
If a beier usm rc is used as the sound module this can be partly simulated... Assuming the pump is rc controlled... Just a y line off the pump control line from the receiver... To the usm as well.. When the pump run the engine sound strarts... And stops after x secs(configurable)... Even better you may be able to add the track motors as other inputs... To keep the sound running.
AP
Old 09-17-2014, 06:20 PM
trucker n's Avatar
Can't u connect to one of the other valves so when working boom or stick it will rev up and down
