Old 09-20-2014, 08:59 PM
Default Re: Support legs motor voltage?
Originally Posted by mavrick0 View Post
Travis would be correct that the legs only use 3v. I would try the winch controller at 3v and see what happens before increasing the voltage on the motor and possibly damaging it. If it won't work at 3v then you could always install a large load resistor to drop down the voltage from the minimum 6v that the controller uses to around 3v.
Thank you maverick0. I will try that, but when it comes to the load resistors, it's all Greek to me. If the 3v doesn't work, I'll ask more about the load resistor.
Thanx, Big John
