Old 10-03-2014, 09:44 PM
Default Re: JBC limited NZ
cheers paul,
waiting for better weather then a few more outside shots.
got the conveyors finished and running good.
need to put loader back together, had a bearing failure in the rear diff.
input shaft bearing toast!
got a new gear set from manufacture (free) and put some shims in around main diff gear bearing, and milled a bit of clearance for the diff lock leaver ,also rechecked front diff and fitted shims, milled a bit out the same as rear diff.
need to find a bit of time for a play to see if it is all good.
cheers andy
Old 10-04-2014, 12:26 AM
took the trailer for a drive.
