Old 10-05-2014, 10:38 PM
Default Re: JBC limited NZ
put loader thru so rigorous testing ( just a bit of play time)
and all going well, battery flat again so the excavator needed a bit of a work out.
all going well.
don't know whats up with the mic on the lap top, I may adjust it with a hammer soon.
anyway heres a quick video of this mornings testing.
http://youtu.be/x_vfb__pciE
Old 10-13-2014, 01:18 AM
ok, finally got the signal reversing plug fitted, need to lower the revs a little but pretty happy how it works.
heres a quick video.
http://youtu.be/c4xczKdO-pU
Old 10-13-2014, 01:39 AM
also finished of some shelving and extended the indoor digging area.
Old 10-13-2014, 10:38 PM
had a bit of playtime, have slowed the revs on the signal reversing card, sounds a little better, not revving its head off.
http://youtu.be/NrwASQg5fBA
Old 10-13-2014, 11:00 PM
thebigo thebigo is offline
Great Equipment you have there!! I am just starting, so far i have the excavator like yours and the armageddon dump and my Loader like yours is on it's way. Think I will pull it apart and do the diff's right away. Is that Big dump truck manufactured by you or another outfit?
Old 10-13-2014, 11:46 PM
thanks, takes a while to get a fleet together.
and yes pull the axels and fit shims, also make sure all the bearings are there, mine had the bearings in the axel tube missing, standard tamyia bearing will do the job.
the dump truck , if your talking about the yellow rock truck, I scratch built it from scrap metal I rescued from the rubbish bin, I think there is a post on here under MY JUNK ROCK BUILD, has a hydraulic tipper and electric steering.
need to get some small rams, or make some when time allows for the steering.
heres a quick video of a bit of axel bashing on the loader, still going strong, must be 20 plus batteries and still no problems, cant say the same for the speaker connections, must be shorting on diff lock steel cable.
will fix on next days off.
cheers andy
http://youtu.be/-XmDzvo5B7k
Old 10-14-2014, 08:57 AM
Cooper's Avatar
Cooper Cooper is offline
Red face Re: JBC limited NZ
Now that's a nice wall of fun!!! I had the wife convinced (and myself) that you had the sandbox inside the house. From other posts you could see a couch and looked to be inside. She lets me run them in the house but don't think I could bring dirt in the garage. Although the supports the idea of me building a vacuum truck.
