Now a vacuam truck could come in handy.
As for playing inside. Punishable by death or so ive been told. we bought a new house about a year ago. Wife got itchy feet I said big shed and that was my main want. a week later she found a house with 4 acres of land and huge 4 bay shed . go to the auction and we are the only bidders. next minute we are moving. I will suggest tha vacuam truck idea to help out with the house work. If you dont hear from me again you will know what happened. cheers andy |
also need to point out that there is another use for the shed,
you cant just play with RC consturction modles all day, belive me Ive tried. sometimes you need to make things. was lucky enough to get these two toys at a really good price, next to them is my paint box. have fitted a small fan heater at the bottom and cut a slot at top of box to let the heat out. makes painting all year round possible. welders and grinders on other side of shed so lathe and mill dont get covered in unwanted dust. I plan one day to convert the mill into a CNC set up as ive seen it done on the net , looks easy enough but a little costly at the moment. cheers andy ![]() |
http://www.scale4x4rc.org/forums/sho...ght=junk+dozer
heres a link to my dozer build, hope it works. |
Cool build's, Like the truck alot!! I have a mig welder would it still work on this thin of metal sheeting?
David |
Thanks. Yeh a mig will work. Turn if way down.
personaly I used my mig on the thin stuff , just makes for a lot less cleaning up after welding. The only thin part on the truck is the tipper so if you ask an engineering firm to weld it up for you it shouldnt cost too much. the cab is made of rubbish plastic , super glue and a lot of filler. cheers andy |
http://email.photobucket.com/wf/clic...RtT81nokb-2FAg
after numerious requests for how the excavator has been wired for sound. this is the sound modual I got from eagle machienery of aliexpress, the connections arent how I ended up running it in the excavator, I also fitted a signal reversing lead on the 4th valve so revs picked up when the sticks were moved. I will take a few photos on my days off to show which channels i used on the reciver Last edited by andyathome; 10-14-2014 at 11:49 PM. |
