Old 10-14-2014, 04:46 PM
calum_scania's Avatar
Default Re: Fumotec Komatsu 490 LC build
A very detailed and excellent build, thanks very much
I would change the layout of the hose here - having the t-piece like this and the gauge hanging of it might give you problems later on
Calum
Old 10-14-2014, 07:54 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Originally Posted by liftmys10 View Post
Cant wait to see some videos!
I will see what I can do, living here on hill on an island in Malaysia with no landline, our internet is a slow 3G connection with limited bandwidth. So video not really an option at the moment. Maybe I can do it from the free WIFI in the airport.
Calum
Thanks for pointing that out! You are right, I cut the yellow hose at the bottom of the pressure regulator too short. Will replace it when I redo the electrics. The pressure gauge is on a quick disconnect, so normally not there. But that doesn't change the fact that I have to redo those connections. Going to be messy and oily ... have to wait till the wife is out.
Old 10-15-2014, 11:28 PM
Rakthi's Avatar
Had some time this morning to test out the adjusted program on the RC.
On the way out, had to park it so I could open the door. Placed it at the first convenient spot and found out the foot print of the excavator is almost the exact same size as a flat of 24 cans!
Battery is a tight fit
Got the bucket full with gravel from the parking lot (also added some by hand as layer not deep enough), seems to be holding fine like this on a flat surface.
Cheers, Stephan
