Old 10-16-2014, 12:06 PM
Default Re: Fumotec Komatsu 490 LC build
Great pictures and overall thread!
Have fun with it!
Old 06-09-2015, 10:57 AM
Rakthi's Avatar
Rakthi Rakthi is offline
After 8 months, time to check up on the 490 LC ... Been postponing sorting the electrics for too long. The thing worked without a hitch and you couldn't see the mess, so didn't feel the need ...
However when I checked under the hood a veritable mess was apparent. Bit embarrassing really.
Also noticed some chafing of the low pressure return lines.
First "fixed" the awkward fit of the pressure regulator and manometer hook up.
Didn't have to make an oily mess. Just repositioning and fixing it right took care of that.
Added an extra security to the T-connector with some wire to prevent it from moving sideways.
Tried to put the ESCs from the slewing mechanism and pump under the servos of the valves, but that didn't work out.
So just made a quick "box" to toss them in as a temporary solution.
Not really ideal at the moment, but had to sort something out.
Never even got around to shortening the wires. Will do that when I come up with a better tray for the ESCs and receiver. Receiver should be able to fit underneath. and then the antenna can go in a better place too.
Having the antenna sitting on the power connections and looping the + wire around the cable was not my brightest idea. Made for some funny interference.
The receiver and power connections are sitting on a ¼" thick piece of high density foam and some wood (don't ask - but it's teak ) for now until I come up with a better overal solution. Well at least it looks a bit better.
This will need a little more thought put in.
Hopefully this time it doesn't take another 8 months.
Stephan
Old 06-13-2015, 06:20 PM
mcCracken15 mcCracken15 is offline
mcCracken15 is on a distinguished road
Posing pictures with common household items really helps a lot of us! Thanks! can i get a good measurements of the front idler wheel? I have been scratch building mine
And would love to see if mine are to small like i think they are!
Old 06-13-2015, 08:59 PM
Rakthi's Avatar
They are a bit larger than the diameter of a soda can.
Or more accurate (you are lucky I had to take this one off to clean out the dirt that got trapped where it slides in the undercarriage)
