Go Back   RC Truck and Construction > RC Truck's General Discussion. > Get it out of your system! HERE!
Get it out of your system! HERE! You have a gripe,bone to pick, Tamiya vs Wedico or just have to let it out! THIS IS THE ONLY PLACE TO DO IT!
Old 10-20-2014, 07:19 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Default Re: RC4WD 870k loading shovel
Hi Dave,
You Might be better of contacting eagle machinery,
http://www.eaglemach.net/index.php
A andyathome in Australia, bought one it was missing the front fenders, he contacted eagle, with in a week he had the parts, latter on he had same problems with the rear diff,
here what he posted on a different forum about the rear diff problem,
heard a clicking noise in rear diff so I pulled it apart again( after checking it when I first got it).
not good! input shaft bearing completely toast. also found wear in the casting for the diff lock lever , like the casting wasn't big enough to take the complete movement of the arm.
had a bit of a think and also noticed in the casting of the axial tubes there looked like a bearing on the axial was missing?
contacted manufacture , (cant complain about their service) a new gear drive input shaft and axial was posted ,I fitted two tamyia bearings into axial housing , put about two mm of shims in to main diff gear bearing housing .
put it all back together again and perfect.
Ive probably put 25 plus batteries thru the loader so maybe its just natural wear , not too sure on that.
will pull apart in another 10 batteries and check them again.
Regards Cameron.
Old 10-20-2014, 04:04 PM
elvis65 elvis65 is offline
elvis65 is on a distinguished road
Hi all.
well got a reply to my emails today and rc4wd say they have sent me a diff out. (I do need two but one is better than none). why did they not answer emails until I emailed 4 rc mags, put two posts up with pictures on facebook and put it on a good few forums.
yes I am happy they are sending me the parts, but not happy at their service.
all the best
dave
