I worked on the tank and ROP this weekend . I didn't fuss on the inside of the tank , not that it will be seen .
![]() ![]() ![]() ![]() ![]() ![]() ![]() the holes in the center are for spot welding ![]() I need to cut the bolt plates for the bottom of the ROPS then tig em on like the mating plates on the tank .
Looking good Steve. This should definitely add some weight for traction too!
Thanks , Reg
I finally got a lil update . Oil fill caps and vent made and welded it all together . ![]() ![]() ![]() ![]() thanks for looking
