Old 10-30-2014, 09:50 PM
JT Marshall JT Marshall is offline
JT Marshall is on a distinguished road
Default Re: help please !
Thanks guys, I really appreciate the answers ... I posted this on rc group and tamiya trucks and i only got 1 person to respond on rc group..
This is definitely the more helpful place to be...
my next question is have either or anything of you tried the dual motor 3:1 reduction vs the 4:1 reduction aux transmission?
I was thinking of getting the 4:1 aux tranny but then I saw the dual motor kit which would allow me in the future to make said truck an awd.. Does anyone have any experience with either part?
Old 10-31-2014, 01:12 AM
ricm ricm is offline
with a decent truck puller motor or similar, either tranny will give you bags of torque so it comes down to your preferred speed in top gear and how you plan your AWD conversion. Transfer box after the tranny should work with either conversion you mention. Remember though that dual motor will require big Amps so will run the battery down really fast - and with that in mind choose the ESC wisely!
One of the 'simplest' AWD conversions I saw had a planetary gear reduction between motor and gearbox, then the gearbox lower shaft extended out of the front and rear of the gearbox for drive to axles.
Note that the Globe has very limited space between the back of the gearbox and first rear axle (less space than any other truck I think), might be a consideration with your transmission set-up
