Old 11-17-2014, 09:51 PM
Joe25's Avatar
Joe25 Joe25 is offline
Joe25 is on a distinguished road
Default Re: It was going good until...
Fwiw, I had this problem quite a bit when I built static models. And its frustrating as ****
My solution: I made an acrylic box 4'(L) x 4'(W) x 2'(H) (1.2192m x 1.2192m x 0.6096m) with 1 3/4" (4.445cm)
holes drilled in top & sides with 3" (7.62cm) disks mounted 1/8" (0.3175cm) outside the holes.
But there's the problem of gnats which I didn't have (live in a desert) but I bet you could tape some of the paper coffee filters to the inside of the openings it would probably work... just an idea
Top makes a good work area if ya lay a board over it and side can be customized for hand tool storage with the clips for hanging a rake on the wall too
Make peace or Die! 1st Bn 5th Marines
Old 11-18-2014, 08:43 PM
Thank you Joe25, I may build something, but I would like to be able to fold it up when I was done for the day or take it a part. I should be able to figure something out.
Old 11-18-2014, 09:46 PM
Joe25's Avatar
Couple piano hinges should suffice there, rubber gasket along top with a latch... and please Joe is fine
